SmaLL
Post by SmaLL »
:twisted: ........ 11.96@121mph without the nitrous on stock internals at 430whp.
Un tagad tur ir 599 WHP.
Dzineja uzlabojumi :-D
engine mod's :
-turbo : GT3076R / 700177-12 / 63ar
-custom tubular exhaust manifold
-custom short runner intake
-custom large intercooler
-nx nitrous sprayer to intercooler
-nx nitrous system to motor ( 35, 75, 110 shot )
-nx twin nitrous bottles with auto openers, warmer, and perge
-custom fuel rail with return
-rc 750 injectors
-tial wastegate
-tial blow off
-aem plug n play
-aem wideband
-throttle body 65mm
-msd coil and leads
-earl's oil cooler
-upgraded fuel pump
-greddy boost controller
-greddy oil catch can
-3" exhaust that changes to 3" oval out both sides
-11" & 17" burns steal mufflers
-opitma yellow top battery
-dynamic racing battery bracket
-quaife limited slip
-spec stage 3+ custom clutch
-10" & 12" staggered fans
-dcr windage tray and crank scraper
-dcr top end oil modifier
-dcr large oil k&n filter kit
-dcr oil pick up tube
-motul synthetic oil
-k&n air filter
-momentum custom air box (4" intake)
-boost logic turbo blanket
-avid solid motor mounts
-custom rad neck and piping
-custom stainless heat sheilds
-painted valve cover
-billet caps for radiator and oil
-blue silicone hoses, stainless lines with aeroquip fittings
-stock bottom end and head
Valdnieks
Post by Valdnieks »
:lovs:
RAIŅAZAURS
Tomel_q
Audi 80 Quattro
Post by Tomel_q »
:shura: :D
gacciZm
Post by gacciZm »
ledusskapis
Post by ledusskapis »
okartis
Post by okartis »
Tūnēts - nav, stilīgs - pirmajā mirklī šķiet, ka nē. Patiesībā, viens no 977 saražotajiem S6+, konkrētāk 182-ais. No pirmā acu uzmteina, vnk, S6 vai vēl labāk A6 :lol: , zem haubes V8 ar 326 zs jaudu un vēl pilns dažādām niansēm un atšķirībām arī no jaudīgā S6.
nezināju, ka tādi ir :roll:
Ir pieejams parasts s6 ar 4.2 motoru, bet šamas zirgi ap 270 skaitās! Kas ta šitam tik ļoti atšķiras? :neka:
okartis
Post by okartis »
S6+ ir pirmais Quattro GmbH auto, kuru itkā dēļ laika trūkama sertifikācijai nosaca par S6+ nevis RS6.
Standarta aprīkojumā nāk papildus stop signāls, melnas līstes ap logiem, melni jumta reliņi, ksenona tuvās gaismas, BOSE audio, sporta piekare (25mm sēdinājums) (pārējiem tas viss bija dabūnams kā papildaprīkojums).
Instrumentu paneļiem ir trīs krāsu varianti - melns, balts, zils.Liek it kā atkarībā no virsbūves un salona krāsas.
Lielākā atšķirība ir tīri tehniski (tikai viens dzinējs - V8 4.2 un tikai viena kārba - 6 pakāpju manuālā):
V8 4.2l dzinējs ar 32 vārstiem, ar paceltiem maksimālajiem apgriezieniem (red line 7000, apgriezienu ierobežotājs ~7300), līdz ar to arī 326Zs nevis 290Zs. Lai paceltu apgriezienus atvieglināti vārsti. Aizdedze par 25 grādiem agrāka un ieplūdes traktam nav vārstu kompensatoru, kas ļāva uzlikt mazāku eļļas sūkni.
Gaisa filtrs no Audi A8.
Līdzīgs dzinējs vēlāk nāca A8 un A6(C5).
6 pakāpju manuālā kārba ar īsākiem robiem nekā parastajam S6, speciāls Quattro gmbH sporta izpūtējs, priekšā lielāki bremžu diski.
V8 un S4(C4)/S6(C4) ir četrkantīga glāžu atsaite, bet S6 plus apaļa, kāpēc nezinu
#MR
Post by #MR »
atvieglojot dzinēja daļas un pagriežot aizdedzi iegūti 36zs atmosfērai?
okartis
Post by okartis »
...Don't mistake this car for the S4 4.2 or S6 4.2 either (I know it's confusing), two models sold in Europe exclusively. These two cars do not include the chip tuning and new exhaust manifold provided by Quattro Gmbh for the S6 Plus, and have outputs of 280 and 290 hp (DIN), respectively. Result for the S6 Plus: 62 mph (100 km/h) in under 6 seconds and a top speed of 156 mph...
rekords vai senators?
records pa moimu :roll:
es tikai nesaprotu, izskatās jau kruta, bet kā ar tādu var pabraukt :neka: man jau ar savu sēdinājumu ir viss izbesījis :emo:
Nav tas ne Rekords, ne Senators, bet gan Opel Commodore :yo:
Šams ir krutāks par abiem augstāk minētajiem!!! :D
No rekorda atšķiras ar priekšējo optiku un jaudīgāku motoru.
man tādu vajag :D
EsRoltons wrote:man tādu vajag :D
šitiem papildaprīkojumā parasti nāk daudz, daudz rusas! :D
