Aleks
Post by Aleks »
Pārdodu benzīnsukni no e36 98.g stāveja uz 2.0, bet domaju pārejiem arī derēs! 15 ls
roliss
Post by roliss »
Peerku priekseejos spaarnus no golf mk3 hechbeka.
Veelams sarkanaa kraasaa.
ride
Post by ride »
Bmw e34 525 92' Tourings, m50b25, rucka! Kondisens, klimats! 600ls, nav akmenii iekalta, var mainiit! :)
Pm, 28329096!
v1
Post by v1 »
Pārdošanā komplekts ar Nokya Arctic white lampiņām. Sūtiju no USA, bet tomēr izdomāju sūtīt citas..
Cena 21 ls
26199896 vai PM
lampiņas 2.jpeg (1.33 KiB) Viewed 9192 times
stefs
Post by stefs »
Paardodu divus priekseejos H&R coiloverus BEZ atspereem. Lietoti. Alumiinija statnes, gredzeni augstuma reguleesanai komplektaa. Varbuut kaadam noder, lai paartaisiitu prieks sava auto, bet originaali naak no Saab 9-3ss. Cena - 50Ls (2gb.)
*bildee redzamie coili ir tieshi taadi kaa tirgoshanaa.
Paardodu SAAB 9-3SS (opel) priekseejos plauktus. Abi ideaalaa staavoklii, sharniiri perfekti. Cena 30Ls gb. (ja njem abus, tad 50Ls)
DER: Saab 9-3ss no 2003-2006
Opel Vectra C no 2003-2005
Paardodu JAUNU BRAX IPC 1.000.000 1 Farad High-End Powercap. Cena - 40Ls (veikalos cena ap 200eiro)
Technische Daten IPC 1.000.000:
Kapazität..................................................................................................................................1.000.000 mF
Innenwiderstand......................................................................................................................< 1 mOhm
Überspannungsschutz.................................................................................................................ab 17,5 V
Durchmesser......................................................................... ....................................................75 mm
Höhe.................................................................................... ...................................................282 mm
Saab 9-3 SS AERO amortizatoru un atsperu komplekts. (DER OPEL VECTRA C no 2003-2005.g.) Perfektaa staavoklii. Komplektaa amortizatoru putekljugumijas. Der saab 9-3 SS no 2003-2006.g. visu tipa dzineejiem. Amortizatori gaazinieki, atsperes ir ar 15mm seedinaajumu. (iznjemot 2.8T V6). Cena - 60Ls
Paardodu JUNU njerzas DOWNPIPE. Stiprinaajums GARETT turbiinai. 3" izeja, klaat njerzas gofra, vieta zondei. Gatavots prieksh mazda 323 1.8T, bet pielaagot var daudziem auto. Cena - 40Ls
*bilde ir tikai piemeers, bet izvietojums liidziigs
info: 26430198 vai [email protected]
Saab 9-3SS Aero
Drosminsh
Post by Drosminsh »
Meklēju Nissan Pathfinder starteri. 3,3l bendzīns 1997.gada automāts varbūt der arī no kāda cita darpaka? :hvz:
Un ja kādam vajaga tad ir tā paša Pathfindera orģinālie asv lukturi. Piedāvājumus lūdzu uz PM.
Artis12
Post by Artis12 »
Pērku augstas pretestības sprauslas.
550 ccm.
PM vai 29613314
edit:
kā arī celicas (90-93) bagāžnieka vāka amortizatorus, strādājošus.
Wu-Ryder
Post by Wu-Ryder »
Pārdod rezerves daļas no šādas automašīnas:
BMW E36
m50b20
1995g
Tourings
Pr. el logi
Sista šofera puse
Tel. 25555122
[email protected]
(c) 3BMotorsport
stefs
Post by stefs »
Jaunas ZEMAAKAS cenas VISAM!!!
Paardodu JAUNUS WISECO virzuljus. Cena - 165.00Ls
Der: Mazda GT-R
Mazda GT-X
Mazda 323 / 323F / Protege 1.8T BG
Mazda MX-5 1.8T
Mazda MX-3 1.8T
*Bore: 84.5mm
Oversize: 0.60
Comp . ratio: 8.5-8.8
Pin dia.: 20mm
Paardodu Jaunus J-SPEC 'GT-R' Connecting Rods. Cena - 145.00Ls
Der: Mazda GT-R
Mazda GT-X
Mazda MX-5 1.8T
Mazda MX-3 1.8T
*The J-Spec GT-R rods are from the Japanese market 323 GT-R built from 93-94 for the WRC. The connecting rods are much stronger than the stock rod used in Mazda B series engines. We have run over 30 psi on our Protege Drag car with these rods and never hurt one. The rods come with bolts and nuts and come in a set of 4.
Fits B6 and BP engines.
Paardodu HERTZ 200mm tumbu sietinjus. Cena - 6Ls (paaris)
Paardodu JAUNU AUDISON Conection fuse distributor BFD21. Cena - 15Ls
Specifikaacija:
POLYCARBONATE CRYSTALS casing, strong and scratch resistant
4 AWG thru 1/0 AWG inputs for any current demand
SMBTM (solid machined brass) construction for better current transfer
PLATINUM SATIN finish for enhanced cosmetics
KNURLED SCREWS for better contact with the attached wire
RECESSED inset cable collar for protection against “stray” wire strands
TWO AND FOUR POSITION AFS
Paardodu HERTZ HL70 midrange skaljrunjus. Komplektaa gredzeni smukaakai ieinstaleeshanai. Cena - 25.00Ls
Kad ieinstaleeti izskataas saadi:
Technical Specifications:
Component : Double Magnet Neodynium REN® Polypropylene cone midrange
Sensitivity : 92dB/SPL
Power Handling : 100WPeak Power 50w Continuous Program Power
Frequency Range : 200Hz - 14kHz
Impedance: 4 Ohm
Paardodu AUDISON CONECTION auto audio plusa vada drosinaataaju. Cena - 8.00Ls
FEATURES:
POLYCARBONATE casing, strong and scratch resistant
4 AWG inputs for high current demand
NICKEL SATIN finish for enhanced cosmetics
AFS FUSE 15 A
Paardodu lietotas, bet bez probleemaam aizdedzes spoles. Lietotas ap 5000km. Ir 3.gb. Cena - 25Ls gb. (ja njem 3gb. tad cena 55Ls)
Der: Saab 9-3ss 2.0t / 2.0T Aero no 2003.g.-
Opel Vectra c 2.0t no 2003-2005.g.
Paardodu JAUNUS APracing priekseejos bremzu diskus. Cena - 45.00Ls
Izmeers: 302 x 28
Der: Saab 9-3ss no 2003-
Cadillac CTS no 2003-2005.g.
Paardodu JAUNU Shortshifter. Cena - 40Ls
Der: Mazda 323 / 323F BG 1990-1994.g.
Mazda 323 / 323F 1999-2002.g.
Mazda MX3 1992-1997.g.
*Mazda Performance Short Shifters are CNC machined to aircraft industry tolerances and coated in our unique polished black finish for ultra low friction and extreme corrosion resistance.
*Features:
- 2" height reduction
- 50% throw reduction
Paardodu CORKSPORT polieteleena izpuuteeja tureetaaja bukses. JAUNAS. Cena - 20Ls 6gb.
*The stock rubber exhaust hangars allow a certain amount of movement under normal driving conditions. When you install a performance exhaust system the clearances from larger exhaust piping and different production designs give you less clearance between the car body and the exhaust system. Combined with the stock rubber exhaust hangars you can get a ?bump? or ?thump? from the exhaust system touching the underside of your car driving down the street hitting pot holes or bumps.
Paardodu JAUNU BULLFROG throttle body. Ieejas diametrs 66mm. Cena - 40Ls
Der: Mazda 323 BG 1.6 / 1.8 / 1.8T
Mazda MX3 1.6 / 1.8 / 1.8T
Mazda MX-5 1.8 / 1.8T
Mazda GT-X / GT-R
Iespeejams pielaagot kaadam citam auto.
*Bullfrog Throttle Bodies are bored to micro tolerances, and a new purple anodized butterfly is machines and hand fitted to provide the best idle possible. The velocity stack is tapered to induce high velocity air flow into the intake manifold resulting in super throttle response, increased midrange, and big top end.
Paardodu lietotu Saab 9-3ss 2.0T Aero izpluudes kolektoru. Cena 30Ls
Der: Saab 9-3ss 1.8t / 2.0t / 2.0T
Opel Vectra C 2.0T
u.c. opel ecotec dzineejiem
Paardodu MAZDA 323 BG priexeejo resti. Cena 10Ls
Paardodu JAUNU FLYI'N MIATA lielaakas caurpluusmas degvielas magistraali. Reaalaa kraasa: alumiinija. Cena - 40.00Ls
Der: Mazda 323 1.8 / 1.8T BG modeljiem
Kaa arii var pielaagot citiem 4cilindru motoriem.
*This dual-feed rail ensures that all the cylinders get the fuel they need so you can make power safely. It also maximizes the amount of fuel each injector can deliver. The rail itself is machined out of an aluminium billet and chromed.
*komplektaa NENAAK degvielas slaukas
Paardodu divus priekseejos H&R coiloverus BEZ atspereem. Lietoti. Alumiinija statnes, gredzeni augstuma reguleesanai komplektaa. Varbuut kaadam noder, lai paartaisiitu prieks sava auto, bet originaali naak no Saab 9-3ss. Cena - 45Ls (2gb.)
*bildee redzamie priekseejie coiloveri ir tieshi taadi, kaa paardodu
Paardodu JAUNU BRAX IPC 1.000.000 1 Farad High-End Powercap. Cena - 35Ls (veikalos cena ap 200eiro)
Paardodu JUNU njerzas DOWNPIPE. Stiprinaajums GARETT turbiinai. 3" izeja, klaat njerzas gofra, vieta zondei. Gatavots prieksh mazda 323 1.8T, bet pielaagot var daudziem auto. Cena - 30Ls
Paardodu jaunus sporta benkju stiprinaajumus. reguleejami turp un atpakalj.
Cena 20Ls gb. (ja njem 2gb. tad cena 30Ls)
Der:
Mazda 323 / 323F BG no 1990-1994.g. (sedanam, hechbekam)
*bildee redzamie stiprinaajumi nedaudz atskiraas no reaalajiem.
Powerflex izpuuteeja tureetaaja polieteleena bukses. Cena - 10Ls (3.gb)
JAUNS K&N gaisa filtrs. Iepakojumaa. Cena - 15Ls
Der:
2003 BMW Z3 1.9L L4 F/I - All
2002 BMW Z3 1.9L L4 F/I - All
2001 BMW Z3 1.9L L4 F/I - All
2000 BMW Z3 1.9L L4 F/I - All
2000 BMW 318TI 1.9L L4 F/I - All
2000 BMW 316I 1.6L L4 F/I - E36
1999 BMW Z3 1.9L L4 F/I - All
1999 BMW 318TI 1.9L L4 F/I - Non-US
1999 BMW 318IS 1.9L L4 F/I - All
1999 BMW 318I 1.8L L4 F/I - All
1999 BMW 316I 1.6L L4 F/I - All
1998 BMW Z3 1.9L L4 F/I - All
1998 BMW Z3 1.8L L4 F/I - All
1998 BMW 318TI 1.9L L4 F/I - All
1998 BMW 318IS 1.9L L4 F/I - All
1998 BMW 318I 1.9L L4 F/I - US
1998 BMW 318I 1.8L L4 F/I - All
1998 BMW 316I 1.6L L4 F/I - All
1997 BMW Z3 1.9L L4 F/I - All
1997 BMW Z3 1.8L L4 F/I - All
1997 BMW 318TI 1.9L L4 F/I - All
1997 BMW 318IS 1.9L L4 F/I - All
1997 BMW 318IS 1.8L L4 F/I - All
1997 BMW 318IC 1.9L L4 F/I - US
1997 BMW 318I 1.9L L4 F/I - US
1997 BMW 318I 1.8L L4 F/I - All
1997 BMW 316I 1.6L L4 F/I - All
1996 BMW Z3 1.9L L4 F/I - All
1996 BMW Z3 1.8L L4 F/I - All
1996 BMW 318TI 1.9L L4 F/I - All
1996 BMW 318IS 1.9L L4 F/I - All
1996 BMW 318IS 1.8L L4 F/I - All
1996 BMW 318IC 1.9L L4 F/I - US
1996 BMW 318I 1.9L L4 F/I - US
1996 BMW 318I 1.8L L4 F/I - All
1996 BMW 316I 1.6L L4 F/I - All
1995 BMW Z3 1.9L L4 F/I - All
1995 BMW Z3 1.8L L4 F/I - All
1995 BMW 318TI 1.9L L4 F/I - All
1995 BMW 318TI 1.8L L4 F/I - All
1995 BMW 318IS 1.9L L4 F/I - All
1995 BMW 318IS 1.8L L4 F/I - All
1995 BMW 318IC 1.8L L4 F/I - All
1995 BMW 318I 1.8L L4 F/I - US
1995 BMW 318I 1.8L L4 F/I - Non-US, from 9/95
1995 BMW 316I 1.6L L4 F/I - from 9/95
1994 BMW 318TI 1.8L L4 F/I - All
1994 BMW 318IS 1.8L L4 F/I - Non-US
1993 BMW 318IS 1.8L L4 F/I - Non-US, from 12/93
Saab 9-3SS Aero
Ir pieejamas:
-E36 sedana šofera puses durvis priekšējās
-E36 sedana spārns priekšējais
-E36 sedana šofera puses ķīniešu pavarots tjip tumšais
-E36 sedana blakussēdētāja puses piemīztais pavarots (firmu nezinu)
-E36 sedana šofera puses lapma Depo ar lēcu
-E36 Moldings m-bamperim blakussēdētāja puses ar parkingu, jauns.
Bildes
Ja ir interese PM
ir pieejams viss kas mūsdienās vajadzīgs! par superīgām cenām! sīkāk pm! preces jaunas un iepakojumā!
te mazs piemērs atlaides līdz 40% reālas!
viss kas intresē jautāt pm!
Preces tusējās kurzemes pusē,par piegādi atsevišķi $,bet sarunāt var!
piedāvājums nebūs mūžīgs,līdz martam!
Aleks
Post by Aleks »
steidzami velos nopirkt bmw e36 coupe (nezinu vai ir atshkiriba no sedana) stikla tiriaja slotinjas pashu katu, to stieni pie ka slotinja stiprinas vajadziga vaditajpuses.
JLO
Post by JLO »
Pārdošanā Beltronics RX65
50Ls
v1
Post by v1 »
v1 wrote:Pārdošanā komplekts ar Nokya Arctic white lampiņām. Sūtiju no USA, bet tomēr izdomāju sūtīt citas..
Cena 21 ls
26199896 vai PM
15 ls
Diegzz
Post by Diegzz »
Vajadziga e30 pusas zboraa!! 29325875 vai PM
jurci-s
Post by jurci-s »
Pērku snowborda zābakus 45 izmērs... PM vai 29627383
ride
Post by ride »
Pardodu m52b28 aluminija bloku ar klokeni, klaniem un virzuliem!
ar jaunaam klanu un pamata shaaleem+jauniem gredzeniem! cilindri peec FlexHone, bloka virsma noliidzinaata! blokam atjaunotas skruuvju vietas!
Peec remonta nobraukums-1100km, no kuriem 500km bija iebrauksana!
der virsuu arii m50 galva!
cena par visu+jaunaam skruuveem-150ls :eek:
PM, 28329096!
ride
Post by ride »
Paardodu divus Sparco Sprint sporta benkus, taadi kaa bilde! var dabuut arii Shrot 4punktu jostas! cena 110ls, par abiem!
Pm, 28329096!
stefs
Post by stefs »
Paardodu:
MAF sensors. JAUNS. Cena - 20Ls
Der: SAAB 9-3ss no 2003-2006.g. 1.8t / 2.0t / 2.0T Aero.
*bildee redzamais maf ir lietots, bet paardodas jauns
Paardodu lietotus virzuljus. Nobraukts 116000km. Cena - 50Ls
Der: Der: SAAB 9-3ss no 2003-2006.g. 1.8t / 2.0t / 2.0T Aero.
Paardodu aizmugureejaa bufera luupu. Perfektaa staavoklii. Melna. Cena - 40Ls
Der: SAAB 9-3ss no 2003-2007.g. VISIEM SEDANIEM.
Saab 9-3SS Aero
Tomels
Post by Tomels »
Pārdodu detaļas no BMW m20b20 un m50b20 vanos motoriem vai arī motorus veselus. Tel 22461009, esmu netālu no spices.
