stefs
Post by stefs »
ZEMAAKAS CENAS!
Paardodu gadu lietotus SAAB originaalos priekseejos bremzu diskus. Perfektaa staavoklii. Cena - 35.00Ls
Izmeers: 314mmx28mm
Der: saab 9-3ss 2.0T Aero
Opel Vectra C 3.2 V6 ar so diksku izmeeru
Paardodu Jaunus J-SPEC 'GT-R' Connecting Rods. Cena - 100.00Ls!!!
Der: Mazda GT-R
Mazda GT-X
Mazda 323 / 323F / Protege 1.8T BG
Mazda MX-5 1.8T
Mazda MX-3 1.8T
*The J-Spec GT-R rods are from the Japanese market 323 GT-R built from 93-94 for the WRC. The connecting rods are much stronger than the stock rod used in Mazda B series engines. We have run over 30 psi on our Protege Drag car with these rods and never hurt one. The rods come with bolts and nuts and come in a set of 4.
Fits B6 and BP engines.
Paardodu HERTZ 200mm tumbu sietinjus. Cena - 5Ls (paaris)
Paardodu AUDISON CONECTION auto audio plusa vada drosinaataaju. Cena - 6.00Ls
FEATURES:
POLYCARBONATE casing, strong and scratch resistant
4 AWG inputs for high current demand
SMBTM (solid machined brass) construction for better current transfer
NICKEL SATIN finish for enhanced cosmetics
AFS FUSE 15 A
Paardodu HROMEETU vaarstu vaaku. Komplektaa jauna vaarstu vaaka bliive. Cena - 20.00Ls
Der: Mazda 323 / 323F BG 1990-1994 1.8 / 1.8T
Mazda MX-5 visiem 1.8 / 1.8T motoriem
Mazda GT-X / GT-R
BILDE: download/file.php?id=4587&mode=view" onclick="window.open(this.href);return false;
Paardodu JAUNU AUDISON Conection fuse distributor BFD21. Cena - 10Ls
Specifikaacija:
POLYCARBONATE CRYSTALS casing, strong and scratch resistant
4 AWG thru 1/0 AWG inputs for any current demand
PLATINUM SATIN finish for enhanced cosmetics
KNURLED SCREWS for better contact with the attached wire
RECESSED inset cable collar for protection against “stray” wire strands
TWO AND FOUR POSITION AFS
Paardodu lietotas, bet bez probleemaam aizdedzes spoles. Lietotas ap 5000km. Ir 3.gb. Cena - 15Ls gb. (ja njem 3gb. tad cena 35Ls)
Der: Saab 9-3ss 2.0t / 2.0T Aero no 2003.g.-
Opel Vectra c 2.0t no 2003-2005.g.
MAF sensors. JAUNS. Cena - 16Ls
Der: SAAB 9-3ss no 2003-2006.g. 1.8t / 2.0t / 2.0T Aero.
Opel Vectra C no 2003-2005.g. 1.8t / 2.0T
BILDE: download/file.php?id=4571" onclick="window.open(this.href);return false;
*bildee redzamais maf ir lietots, bet paardodas jauns
Paardodu CORKSPORT polieteleena izpuuteeja tureetaaja bukses. JAUNAS. Cena - 10Ls 6gb.
*The stock rubber exhaust hangars allow a certain amount of movement under normal driving conditions. When you install a performance exhaust system the clearances from larger exhaust piping and different production designs give you less clearance between the car body and the exhaust system. Combined with the stock rubber exhaust hangars you can get a ?bump? or ?thump? from the exhaust system touching the underside of your car driving down the street hitting pot holes or bumps.
Paardodu JAUNU BULLFROG throttle body. Ieejas diametrs 66mm. Cena - 30Ls
Der: Mazda 323 BG 1.6 / 1.8 / 1.8T
Mazda MX3 1.6 / 1.8 / 1.8T
Mazda MX-5 1.8 / 1.8T
Mazda GT-X / GT-R
Iespeejams pielaagot kaadam citam auto.
*Bullfrog Throttle Bodies are bored to micro tolerances, and a new purple anodized butterfly is machines and hand fitted to provide the best idle possible. The velocity stack is tapered to induce high velocity air flow into the intake manifold resulting in super throttle response, increased midrange, and big top end.
BILDE: download/file.php?id=4569" onclick="window.open(this.href);return false;
Paardodu lietotu Saab 9-3ss 2.0T Aero izpluudes kolektoru. Cena 20Ls
Der: Saab 9-3ss 1.8t / 2.0t / 2.0T
Opel Vectra C 2.0T
u.c. opel ecotec dzineejiem
BILDE: download/file.php?id=4570" onclick="window.open(this.href);return false;
Paardodu JAUNU FLYI'N MIATA lielaakas caurpluusmas degvielas magistraali. Reaalaa kraasa: alumiinija. Cena - 30.00Ls
Der: Mazda 323 1.8 / 1.8T BG modeljiem
Kaa arii var pielaagot citiem 4cilindru motoriem.
*This dual-feed rail ensures that all the cylinders get the fuel they need so you can make power safely. It also maximizes the amount of fuel each injector can deliver. The rail itself is machined out of an aluminium billet and chromed.
*komplektaa NENAAK degvielas slaukas
Paardodu divus priekseejos H&R coiloverus BEZ atspereem. Lietoti. Alumiinija statnes, gredzeni augstuma reguleesanai komplektaa. Varbuut kaadam noder, lai paartaisiitu prieks sava auto, bet originaali naak no Saab 9-3ss. Cena - 37Ls (2gb.)
*bildee redzamie priekseejie coiloveri ir tieshi taadi, kaa paardodu
Paardodu jaunus sporta benkju stiprinaajumus. reguleejami turp un atpakalj.
Cena 15Ls gb. (ja njem 2gb. tad cena 25Ls)
Der:
Mazda 323 / 323F BG no 1990-1994.g. (sedanam, hechbekam)
*bildee redzamie stiprinaajumi nedaudz atskiraas no reaalajiem.
Powerflex izpuuteeja tureetaaja polieteleena bukses. Cena - 8Ls (3.gb)
info: 26430198 vai [email protected]
Saab 9-3SS Aero
takeshi
Post by takeshi »
tiek tirgotas rezerves dalas no e36 325tds!sedans!
*durvis
*visi stikli
*ir visa prieksa bleki un ta talak
*miglinieki ar visiem ramisiem
*sparniem patkrilniki
*sture ar airbegu trisstaru
*stures reika
*ideals bagaznieks
*bampers preieksejais aizmugurejais
*stikla skiedras slieksni
*reduktors
*stock aizmugurejas lampas
*prieksa bosh lampas
*pilnais obc 18pogu kompis
*motors
*karba
*abi tilti
*visai amisi ir
*visas piekares dalas
*ir ari ZF karba
utt!
ja intrese pm jeb 20233101
Icikinsh
Post by Icikinsh »
Iesveriet kaads divas 185/60 R14 +-ziemenes... STEIDZAMI un leeti...
28602359
-E36 sedana šofera puses durvis priekšējās (bez mehānisma un motoriņa)
-E36 sedana spārns priekšējais
-E36 sedana šofera puses ķīniešu pavarots tjip tumšais
-E36 sedana blakussēdētāja puses piemīztais pavarots (firmu nezinu)
-E36 sedana šofera puses lapma Depo ar lēcu
-E36 Moldings m-bamperim blakussēdētāja puses ar parkingu, jauns.
Bildes
E39 detaļa nr. 6 - http://www.realoem.com/bmw/showparts.do ... g=30&hl=32" onclick="window.open(this.href);return false; Pilnīgi jauna, iepakojumā. 5 ls
Nevienai garantijas nav, pārsvarā visas ir smuki savos original iepakojumos (tās, kuras nav lietotas). Ja kas interesē, tad uz PM rakstam. Un visas cenas diskutējamas.
Mantas:
3,5” HDD (iepakoti, nelietoti):
Seagate ST3250820A – 250GB 7200 rpm – 2 gab – 20 Ls/gab
SO-DIMM 333 Mhz (visi iepakojumos):
512 MB - 2 gab. – 13 Ls/gab
1 GB - 1 gab. – 20 Ls/gab
DDR DIMM 400 MHz (visi iepakojumos):
512 MB - 2 gab. – 10 Ls/gab
Mobile CPU (mazlietots, protams, nav iepakojumā):
Intel® Core™2 Duo Processor P8400 (3M Cache, 2.26 GHz, 1066 MHz FSB) – 1 gab. – 55 Ls
BILDE
SO-DIMM DDR3 4GB, mazlietots - 45 Ls Info !!!
Izmēros mazs, lieots kompīc. Cena 45 Ls (Protams, runājama)
CPU: AMD AthlonXP 2500+ 1,83 Ghz
RAM: 768 MB
HDD: 120 GB
Video: GeForce FX 5200 128 MB
CD/DVD: Combo Drive
http://bildites.lv/images/1ijmcbn6ch4btgxxjota.jpg" onclick="window.open(this.href);return false;
Šāda tipa BMW original E36 sliekšņi melnā krāsā
http://bildites.lv/images/9b0fe00txtungf6d7v1c.png" onclick="window.open(this.href);return false;
Cena - 50 Ls. Zvanam uz 26959000.
ride
Post by ride »
Pardodu e30 (der arii e36) priekseejos plauktus, pirms 1000km nomainiitas visas 4tras sharas! kaa jaunas, 30ls par abiem plauktiem! :)
mednis
Post by mednis »
pardodu e21 uz detalam 1,8 82 gads 26188974
Pārdod divas nedēļas lietotu ScanPower Multi 500 UPS mājas elektronikas aizsardzībai
Ražots Latvijā!
Multimediju aizsardzība
Ar Multi Jūsu tehnika būs drošībā un kalpos ilgāk. Ja mājās pazudīs elektrība, Jūs, atšķirībā no kaimiņa, noskatīsieties futbola spēles pārraidi līdz galam.
Multi ir paredzēts tieši multimediju (TV, spēļu konsole, mūzikas centrs vai mājas kinozāle) un nelielas jaudas mājas elektronisko ierīču (piemēram, elektronisko pulksteņu vai radiotelefonu un faksa aparāta) aizsardzībai un autonomajai barošanai. Protams, tas izmantojams arī datora aizsardzībai un barošanas kontrolēšanai. Jaudīgākām iekārtām, piemēram, ledusskapim vai veļas mazgājamai mašīnai, Multi gan būs par mazu - tad jāizvēlas lielākas jaudas UPS.
AVR
Visiem Multi modeļiem ir iebūvēta Automātiskās sprieguma regulācijas (AVR) funkcija. Tā nodrošina nevainojamu UPS darbību nepārejot bateriju režīmā, tīkla spriegumam svārstoties no 165 līdz 275 voltiem. Tas nozīmē, ka šī iekārta ir pilnībā piemērots risinājums vietām, kur novērojama sprieguma nestabilitāte, piemēram, lauku reģionos.
RS232 kontroles interfeiss
UPS kontroles programmatūra UPSilon 2000 (arī UPSmart programmatūra) nodrošina Navitas sērijas UPS automātisku izslēgšanos, programmatūras ieslēgšanu un izslēgšanu, un daudzas citas mūsdienīgas strāvas pārvaldības funkcijas.
Specifikācija
Jauda 500VA/300W
Topoloģija Line-interactive
Signāla forma Simulēta sinusoīda
Ieejas sprieg.1 165 - 275 V
Izejas sprieg. 230 V ± 10%
Pārslēgšanās < 4 ms
Indikators Gaismas diodes
Darbības laiks2 8-30 min.
Izejas 2gb parastās, 2 gab. IEC
Baterijas 12 V/21 W x 1
Izmēri 107x228x160 mm
Svars 4,5 kg
CENA: 15Ls
Gekons
Post by Gekons »
Pārdodu detaļas no m20b20 85. gada Coupe. Ir motors piekare, salonam melnā abšivka.Cenas runājamas. Sedana krēsli, viens mazliet papluinīts- 5Ls. Labā stāvoklī-10 Ls. Metāla diski R14. -20 Ls. PM, vai 25908508. http://foto.inbox.lv/mohabich/Uz-paardoshanu" onclick="window.open(this.href);return false;
Tions
Post by Tions »
Pardodas no e30
Pakalejais tilts ar jauniem Limforder sailenblokiem 25Ls
Videja konsula ar kasetem 10Ls
Jaunas bremzu trosites prieks disku bremzem 15Ls
Pakalejie rocenes Feroodo loki ar jaunam atsperem utt 20Ls
Ir ari patkrilniki laba stavokli un visadas salona plastmasas...
Pakalejie sanu logi 4 gab par katru 5Ls
Aizmugurejais logs 10Ls
Barabanu plaukti ar visiem lokiem par abiem 10Ls
Prieksejais vecais fartuks 15Ls
Pakalejais orginalais bundulis diezgan pasmags 5Ls
Laipni lugti PM vai 29918180
E30 drift car...
RPM motorsport
family guy
Post by family guy »
mosh kadam vajag pasivo kinozales subiti,.mazinjsh,kompakts un skan normali-respektivi pie ka slegsi,tā skanēs max 150w
pa kkadiem 15 ls atdoshu.. PM
Locis
Post by Locis »
Pārdodu:
aizmugurējo difuzoru no E36 M-bampera,ideālāa stāvoklī,tikai ir viena nianse pie izpūtēja cauruma-20ls-
moldingus no m-bampera-10ls-
kā arī diezgan cietušu aizmugurējo m-bamperu -15ls-bildes pēc pasūtījuma uz pm ;)
Cenas nav akmenī iekaltas..
Pērku: E36 šofera puses ZKW miglenieku un -96.9 melna plastmasas ''nāsu'' komplektu,kā arī priekšējo šofera puses ''padkriļņiku''-oriģinālo,pilnīgi veselu.
PM vai 26548865
stefs
Post by stefs »
ZEMAAKAS CENAS!
Izmeers: 314mmx28mm
Der: Mazda GT-R
Mazda GT-X
Mazda MX-5 1.8T
Mazda MX-3 1.8T
FEATURES:
AFS FUSE 15 A
Mazda GT-X / GT-R
Specifikaacija:
Mazda GT-X / GT-R
Opel Vectra C 2.0T
Paardodu divus priekseejos H&R coiloverus BEZ atspereem. Lietoti. Alumiinija statnes, gredzeni augstuma reguleesanai komplektaa. Varbuut kaadam noder, lai paartaisiitu prieks sava auto, bet originaali naak no Saab 9-3ss. Cena - 33Ls (2gb.)
Saab 9-3SS Aero
lapsins
Post by lapsins »
nerūsējis c3 bagāžnieks no avanta
piedāvājiet cenu PM vai 28289731 (tele2) vai 26443025 (lmt)
atrodas ādažos
Ren
Post by Ren »
Nav kadam uz pardoshanu kaada 28cm sporta stuuriite?
Ja kas PM :roll:
ERJ
EMils
Post by EMils »
Pērku priekš e30 touring:
*Priekšējie spārni, vēlams bez pagriezienlampām, baltā krāsā.
*sēdinātas atsperes 318 touring kādi 60/40 mm
*borbet a 17" disku centri.
*priekšējā mazā lūpa dīzēļa fartukam.
Elviss
Post by Elviss »
Perku.
1)e36 cupe prieksejos sparnus bez pavarotu vietam, krasas kods "BMW-calypsorot-metallic"
bez ruslana un laba stavoklii.
2)bmw zimiti ko piespraust pie bagaznieka vaka, laba stavoklii. :yo:
Pardodu.
e36 cupe prieksejos pavarotus smouk (baltie tonetie)
abi 9ls :hvz:
Tomels
Post by Tomels »
Pārdodu detaļas no M50B20 vanos motora no e36.
Tel 22461009
Artis12
Post by Artis12 »
Pērku BMW 320, 323, 325 E30.
Cenā ap 300 Ls un TA.
Vēlams kupeju.
Nauda ir.
Vai arī gatavu variantu ar M50b25 iekšā cenā zem 700 Ls.
PM/PN
SmallDeree
Post by SmallDeree »
Kuku!? :hvz:
SmallDeree wrote:Labprat nopirktu labus atmetamos Recaro kreslis, 2vus gabalus.
Pm or 29333432
