ZEMAAKAS CENAS!
Paardodu gadu lietotus SAAB originaalos priekseejos bremzu diskus. Perfektaa staavoklii. Cena - 35.00Ls
Izmeers: 314mmx28mm
Der: saab 9-3ss 2.0T Aero
Opel Vectra C 3.2 V6 ar so diksku izmeeru
Paardodu JAUNUS WISECO virzuljus. Cena - 145.00Ls
Der: Mazda GT-R
Mazda GT-X
Mazda 323 / 323F / Protege 1.8T BG
Mazda MX-5 1.8T
Mazda MX-3 1.8T
*Bore: 84.5mm
Oversize: 0.60
Comp . ratio: 8.5-8.8
Pin dia.: 20mm
Paardodu Jaunus J-SPEC 'GT-R' Connecting Rods. Cena - 125.00Ls
Der: Mazda GT-R
Mazda GT-X
Mazda MX-5 1.8T
Mazda MX-3 1.8T
*The J-Spec GT-R rods are from the Japanese market 323 GT-R built from 93-94 for the WRC. The connecting rods are much stronger than the stock rod used in Mazda B series engines. We have run over 30 psi on our Protege Drag car with these rods and never hurt one. The rods come with bolts and nuts and come in a set of 4.
Fits B6 and BP engines.
Paardodu HERTZ 200mm tumbu sietinjus. Cena - 5Ls (paaris)
Paardodu HERTZ HL70 midrange skaljrunjus. Komplektaa gredzeni smukaakai ieinstaleeshanai. Cena - 18.00Ls
Kad ieinstaleeti izskataas saadi:
Technical Specifications:
Component : Double Magnet Neodynium REN® Polypropylene cone midrange
Sensitivity : 92dB/SPL
Power Handling : 100WPeak Power 50w Continuous Program Power
Frequency Range : 200Hz - 14kHz
Impedance: 4 Ohm
Paardodu AUDISON CONECTION auto audio plusa vada drosinaataaju. Cena - 6.00Ls
FEATURES:
POLYCARBONATE casing, strong and scratch resistant
4 AWG inputs for high current demand
SMBTM (solid machined brass) construction for better current transfer
NICKEL SATIN finish for enhanced cosmetics
AFS FUSE 15 A
Paardodu HROMEETU vaarstu vaaku. Komplektaa jauna vaarstu vaaka bliive. Cena - 20.00Ls
Der: Mazda 323 / 323F BG 1990-1994 1.8 / 1.8T
Mazda MX-5 visiem 1.8 / 1.8T motoriem
Mazda GT-X / GT-R
BILDE:
download/file.php?id=4587&mode=view" onclick="window.open(this.href);return false;
Paardodu JAUNU AUDISON Conection fuse distributor BFD21. Cena - 10Ls
Specifikaacija:
POLYCARBONATE CRYSTALS casing, strong and scratch resistant
4 AWG thru 1/0 AWG inputs for any current demand
PLATINUM SATIN finish for enhanced cosmetics
KNURLED SCREWS for better contact with the attached wire
RECESSED inset cable collar for protection against “stray” wire strands
TWO AND FOUR POSITION AFS
Paardodu lietotas, bet bez probleemaam aizdedzes spoles. Lietotas ap 5000km. Ir 3.gb. Cena - 15Ls gb. (ja njem 3gb. tad cena 35Ls)
Der: Saab 9-3ss 2.0t / 2.0T Aero no 2003.g.-
Opel Vectra c 2.0t no 2003-2005.g.
MAF sensors. JAUNS. Cena - 16Ls
Der: SAAB 9-3ss no 2003-2006.g. 1.8t / 2.0t / 2.0T Aero.
Opel Vectra C no 2003-2005.g. 1.8t / 2.0T
BILDE:
download/file.php?id=4571" onclick="window.open(this.href);return false;
*bildee redzamais maf ir lietots, bet paardodas jauns
Paardodu CORKSPORT polieteleena izpuuteeja tureetaaja bukses. JAUNAS. Cena - 16Ls 6gb.
*The stock rubber exhaust hangars allow a certain amount of movement under normal driving conditions. When you install a performance exhaust system the clearances from larger exhaust piping and different production designs give you less clearance between the car body and the exhaust system. Combined with the stock rubber exhaust hangars you can get a ?bump? or ?thump? from the exhaust system touching the underside of your car driving down the street hitting pot holes or bumps.
Paardodu JAUNU BULLFROG throttle body. Ieejas diametrs 66mm. Cena - 30Ls
Der: Mazda 323 BG 1.6 / 1.8 / 1.8T
Mazda MX3 1.6 / 1.8 / 1.8T
Mazda MX-5 1.8 / 1.8T
Mazda GT-X / GT-R
Iespeejams pielaagot kaadam citam auto.
*Bullfrog Throttle Bodies are bored to micro tolerances, and a new purple anodized butterfly is machines and hand fitted to provide the best idle possible. The velocity stack is tapered to induce high velocity air flow into the intake manifold resulting in super throttle response, increased midrange, and big top end.
BILDE:
download/file.php?id=4569" onclick="window.open(this.href);return false;
Paardodu lietotu Saab 9-3ss 2.0T Aero izpluudes kolektoru. Cena 20Ls
Der: Saab 9-3ss 1.8t / 2.0t / 2.0T
Opel Vectra C 2.0T
u.c. opel ecotec dzineejiem
BILDE:
download/file.php?id=4570" onclick="window.open(this.href);return false;
Paardodu JAUNU BRAX IPC 1.000.000 1 Farad High-End Powercap. Cena - 30Ls (veikalos cena ap 200eiro)
Technische Daten IPC 1.000.000:
Kapazität..................................................................................................................................1.000.000 mF
Innenwiderstand......................................................................................................................< 1 mOhm
Überspannungsschutz.................................................................................................................ab 17,5 V
Durchmesser......................................................................... ....................................................75 mm
Höhe.................................................................................... ...................................................282 mm
Paardodu JAUNU FLYI'N MIATA lielaakas caurpluusmas degvielas magistraali. Reaalaa kraasa: alumiinija. Cena - 30.00Ls
Der: Mazda 323 1.8 / 1.8T BG modeljiem
Kaa arii var pielaagot citiem 4cilindru motoriem.
*This dual-feed rail ensures that all the cylinders get the fuel they need so you can make power safely. It also maximizes the amount of fuel each injector can deliver. The rail itself is machined out of an aluminium billet and chromed.
*komplektaa NENAAK degvielas slaukas
Paardodu divus priekseejos H&R coiloverus BEZ atspereem. Lietoti. Alumiinija statnes, gredzeni augstuma reguleesanai komplektaa. Varbuut kaadam noder, lai paartaisiitu prieks sava auto, bet originaali naak no Saab 9-3ss. Cena - 37Ls (2gb.)
*bildee redzamie priekseejie coiloveri ir tieshi taadi, kaa paardodu
Paardodu JUNU njerzas DOWNPIPE. Stiprinaajums GARETT turbiinai. 3" izeja, klaat njerzas gofra, vieta zondei. Gatavots prieksh mazda 323 1.8T, bet pielaagot var daudziem auto. Cena - 30Ls
*bilde ir tikai piemeers, bet izvietojums liidziigs
Paardodu jaunus sporta benkju stiprinaajumus. reguleejami turp un atpakalj.
Cena 15Ls gb. (ja njem 2gb. tad cena 25Ls)
Der:
Mazda 323 / 323F BG no 1990-1994.g. (sedanam, hechbekam)
*bildee redzamie stiprinaajumi nedaudz atskiraas no reaalajiem.
Powerflex izpuuteeja tureetaaja polieteleena bukses. Cena - 8Ls (3.gb)
JAUNS K&N gaisa filtrs. Iepakojumaa. Cena - 12Ls
Der:
2003 BMW Z3 1.9L L4 F/I - All
2002 BMW Z3 1.9L L4 F/I - All
2001 BMW Z3 1.9L L4 F/I - All
2000 BMW Z3 1.9L L4 F/I - All
2000 BMW 318TI 1.9L L4 F/I - All
2000 BMW 316I 1.6L L4 F/I - E36
1999 BMW Z3 1.9L L4 F/I - All
1999 BMW 318TI 1.9L L4 F/I - Non-US
1999 BMW 318IS 1.9L L4 F/I - All
1999 BMW 318I 1.8L L4 F/I - All
1999 BMW 316I 1.6L L4 F/I - All
1998 BMW Z3 1.9L L4 F/I - All
1998 BMW Z3 1.8L L4 F/I - All
1998 BMW 318TI 1.9L L4 F/I - All
1998 BMW 318IS 1.9L L4 F/I - All
1998 BMW 318I 1.9L L4 F/I - US
1998 BMW 318I 1.8L L4 F/I - All
1998 BMW 316I 1.6L L4 F/I - All
1997 BMW Z3 1.9L L4 F/I - All
1997 BMW Z3 1.8L L4 F/I - All
1997 BMW 318TI 1.9L L4 F/I - All
1997 BMW 318IS 1.9L L4 F/I - All
1997 BMW 318IS 1.8L L4 F/I - All
1997 BMW 318IC 1.9L L4 F/I - US
1997 BMW 318I 1.9L L4 F/I - US
1997 BMW 318I 1.8L L4 F/I - All
1997 BMW 316I 1.6L L4 F/I - All
1996 BMW Z3 1.9L L4 F/I - All
1996 BMW Z3 1.8L L4 F/I - All
1996 BMW 318TI 1.9L L4 F/I - All
1996 BMW 318IS 1.9L L4 F/I - All
1996 BMW 318IS 1.8L L4 F/I - All
1996 BMW 318IC 1.9L L4 F/I - US
1996 BMW 318I 1.9L L4 F/I - US
1996 BMW 318I 1.8L L4 F/I - All
1996 BMW 316I 1.6L L4 F/I - All
1995 BMW Z3 1.9L L4 F/I - All
1995 BMW Z3 1.8L L4 F/I - All
1995 BMW 318TI 1.9L L4 F/I - All
1995 BMW 318TI 1.8L L4 F/I - All
1995 BMW 318IS 1.9L L4 F/I - All
1995 BMW 318IS 1.8L L4 F/I - All
1995 BMW 318IC 1.8L L4 F/I - All
1995 BMW 318I 1.8L L4 F/I - US
1995 BMW 318I 1.8L L4 F/I - Non-US, from 9/95
1995 BMW 316I 1.6L L4 F/I - from 9/95
1994 BMW 318TI 1.8L L4 F/I - All
1994 BMW 318IS 1.8L L4 F/I - Non-US
1993 BMW 318IS 1.8L L4 F/I - Non-US, from 12/93
info: 26430198 vai
[email protected]
