Drifts
Viss par un ap autosportu.
Burnout Drift team
Re: Drifts
anarhists wrote:Tīri intereses pēc ( man simpatizē rotordzinēji ) - kāds motors ir K.Bluša RX-8 ?
Renesis vai 13B no RX7 ? pēc 4 rotornieka neizskatījās.
Varbūt kāds zina vairāk par to auto ?
Ja tur nekas nav mainījies, tad ir tā pat kā Tonija laikos.
speedhunters.com wrote:That's not a normally aspirated Renesis... hell no, this car builds power! What lies in this engine bay is a 9.0 compression street ported 13B-REW 2-rotor turbocharged motor, pushing 394 horsepower at 8600rpm and 322 ft/lbs of torque at 6800rpm.
The engine builds its power using a Bullseye Power S372 turbo, SARD wastegate, Blitz boost controller, a Haltech E8X unit for management, and GM LS-1 ignition coils, which seem to be fairly popular for rotaries nowadays. Fuel injectors are 1680cc secondary and 850cc for the primary, mated with with a SARD fuel pressure regulator, Walbro in-tank fuel pump, and a KG Parts fuel rail. Air gets sucked in through an HKS Super Flow intake, and pushed out through a customized 13B-REW T3 exhaust manifold, which then routes to a custom 3 inch titanium exhaust. Tony chose to use a custom v-mount setup with a Ron Davis radiator and GReddy intercooler (Skyline core) to keep the engine breathing cold air, with custom piping and end tanks as well.
Aside from a 13B-REW swap, this RX8 also uses a 1995 FD3S transmission, Exedy twin plate clutch, and Tomei Technical Trax LSD.
http://speedhunters.com/archive/2009/01 ... s-rx8.aspx
Paraksts aizbrauca.. :drive:
anarhists
Re: Drifts
Post by anarhists »
Tu gribi teikt ka šis konkrētais RX8 ir tas pats Tony Angelo RX8 ? Nopietni, bez p.. ?
anarhists
Re: Drifts
anarhists wrote:Tu gribi teikt ka šis konkrētais RX8 ir tas pats Tony Angelo RX8 ? Nopietni, bez p.. ?
Vismaz visur, kur izskanējusi info, tad jā, tas pats RX-8, ar kuru Angelo slidinājās iekš Formula D.
Guntijs
Re: Drifts
Post by Guntijs »
Ir ir tas pats - to jau vairākkārt runājām arī ar viņu :)
Re: Drifts
Pašlaik izskatâs, ka ir viena brìva vieta šodienas braucienam uz EE. Ja kãdam ir vélme, zvanat man.
Izbraucam ap 16.00
marrs
Re: Drifts
Post by marrs »
mos kadu vēl vel interese doties uz igauniju driftu izbraucam pus 12
ja kas 28342186 martins
wwd fail
Re: Drifts
Re: Drifts
Vakardienas drifts Krisha skatījumā. :shura:
Re: Drifts
Re: Drifts
Brīnos, ka Guntijs nav noziņojis, labi, ka pats pamanīju, ka šodien, 18.30 mani varēs dzirdēt pa autoziņām.
http://autozinas.fm/jaunumi/radio-etera ... es-6junija
Re: Drifts
Eu, a šito normāli pa radio ar var klausīties, vai tikai netā?
Re: Drifts
FM 99.0
Guntijs
Re: Drifts
Post by Guntijs »
Ups, jā - šodien tik pats pamanīju, ka esi ielikts :)
Kolēģe piekoriģēja topiku, tāpēc es nepamanīju :o
Re: Drifts
Viņa arī bija sajaukusi dienas :D
Tagad būs rīt, 7.jūn ;)
Re: Drifts
Izlasīju, ka Powerā visi normāli cepjas par to, ka netiku tālāk un "zaudēju" tandēmās :emo:
Re: Drifts
Lambertino wrote:Izlasīju, ka Powerā visi normāli cepjas par to, ka netiku tālāk un "zaudēju" tandēmās :emo:
Nu, un tavs viedoklis? :D
Re: Drifts
Re: Drifts
Līdzīgs kā pagājušā gadā, noslēguma posmā LT par kvalifikāciju
Nezinu toč kā man ir jābrauc, lai tiesnešiem patiktu :hvz:
Wu-Ryder
Re: Drifts
Post by Wu-Ryder »
Principā jau hvz kas un kā tur, ko tiesneši izdomājuši. Kā arī stulbi ka tieši Lambertam bija jāupurējas, lai vismaz viens LT braucējs uzkāptu pēc kausa.
Jo sajūta jau jokaina ne, ka LV braucēji visās klasēs noloka ķipīšus. Kā arī cīņas tik savā starpā :D
(c) 3BMotorsport
Re: Drifts
Biku sajauci, EE, nevis LT, bet nu ok :D
Tie kas nebija klāt var redzēt paši un izteikties ;)
Vatix nopublicēja video - http://www.youtube.com/watch?v=tqUnsaqG ... r_embedded
